dougmacm
I've never owned a Pressure Washer and just borrowed an Electric AR Blue Clean 142S from a friend to simplify cleaning up my black walnut harvest.
Had only around 60 nuts collected so far (the trees will be raining nuts any day now) for my test run. First put all the de-hulled nuts in a 5 gallon pail full of water and agitated them with a drywall mud paddle on a drill which took off some of the gunk and separated the no-good "floater" nuts. Then put all the good ones in a milk crate and blasted them with the PRESSURE WASHER for a few minutes ... it did a great job of cleaning the rest of the gunk off and was much faster & easier than the hose & scrub brush method I did last year with around 300 nuts.
Anyway, this is a cheapie ... $90 Pressure Washer (1.4 GPM / 1500 PSI / 12A) ... he's had it for a few years and put a lot of hours on it and has been really happy with it's performance.
https://www.arnorthamerica.com/produ...-washer/ar142s
I definitely don't want a GAS one so thinking I would pick up something similar but "a little" more powerful and am looking at a few different ones under $150.
SUN JOE SPX3000 is 1.76 GPM / 2030 PSI / 14.5A … $150 in stock at local Menards (currently ON SALE for $130).
https://www.snowjoe.com/products/sun...ressure-washer
They give a lot of details on their site including pump life expectancy of 300-500 hours.
AR Blue Clean 240S is 1.4 GPM / 1700 PSI / 13A … $120 from Amazon or special order at Home Depot.
https://www.arnorthamerica.com/produ...-washer/ar240s
Web site claims they are one of the oldest PW companies and they build only quality pumps … but no real specifics or Q&A's like on Sun Joe site.
Craftsman CMXTPAV1800 is 1.2 GPM / 1800 PSI / 13A … $120 in stock at local Menards
https://www.menards.com/main/outdoor...3578415&ipos=6
This has an AR pump and the exact handle assembly and other features as the AR 240S, which makes me think AR is making this one for Craftsman. Model is not listed on Craftsman site.
SUN JOE also makes a model with similar specs to the above two (SPX1501 1.8 GPM / 1800 PSI / 13A) ... $98 from Amazon or special order at Walmart.
https://www.snowjoe.com/products/sun...1-8-gpm-13-amp
The AR models have a 1 year warranty, the SUN JOE and Craftsman are 2 year.
I'm leaning between the Sun Joe & Craftsman that are available at Menards … just waiting to hear back from Craftsman on details such as a copy of the Owners Manual and pump life expectancy.
I think I will find lots of uses for this around the house besides walnuts … siding and deck on the north side of my house for starters !!
Anyone have any feedback on any of these models or any other electric pressure washer ??
Thanks,
Doug
Thanks,
Doug
