OK, so today I replaced the head gasket and reinstalled the head. Weirdly enough the compression was lower now! The torque spec I found was lower than I could dial in on my torque wrench, so I went a little higher. I thought f*ck it...I'll just put everything back together anyway.
Before I reinstalled the carb I squirted some gas straight into the intake and pulled the cord. It started straight away and revved up and died. Encouraging!
With the carb back, without the plate (that sits on top with the choke linkage), I pulled the cord again...nothing. A little squirt into the throat and the d*mn thing started! With a little fiddling with the mix screws I had it running well enough to put the plate back. That thing is not that intuitive, but I have seen a video of how to set it up and was able to get it pretty good. More fiddling with the main and idle mixing screws and it was running sweet! :biggrin: I ran it back and fourth on the street doing small adjustments on the main mixture screw, stopped it and started it again with no effort! I think it's fixed!! :thumbsup:
The only thing that I'm not super happy with is the governor. When I engage the mower deck the rpms dives and I can't really see the governor arm moving that much. When I had it running before all this fixing the arm moved much more and you could clearly hear that it worked the way it's supposed to. It's not super critical, with enough throttle there the engine copes with the load but it would be nice if the governor kicked in when needed.
