UltramanNick
I hope the experts here can help me out.
I have a YardMachine mower with a B&S engine (500). It was working fine two days ago, but suddenly stopped (i.e. no gas). I checked the gas, oil, everything looked fine. I pumped the primer and I didn't "feel" any liquid being pumped....all I heard was just "hsst, hsst." Hm. I decided to wait until the next day thinking I may have flooded it.
Still no start. Still, the primer just kept hissing. So I took off the air filter (which I had cleaned a few weeks ago), took off the fuel tank and dumped the old gas, cleaned the carb, checked the fuel lines....I'm no mechanic, but everything looked clear and good. I put it back together, got some fresh gas, put it in....and then pumped the primer. NOW I felt the liquid being pumped into the engine. The mower started.....ran irregularly for about 30 - 45 seconds, then died (i.e. out of gas). Tried the primer again, just air.
It appears that the engine ran with just the amount of gas inside the mower after it got primed and then died. So why isn't the gas still flowing into the engine?
So is gas just not getting to the engine somehow? The primer is only used to START it going, right? What else can I check without having to tear is apart even more? Any help would be much appreciated.
