Cluthc releases at very top of pedal travel on Murray Rideer
wilburn cox
On 7/13/2019 I posted a question about problem with clutch or transmission. the Murray is model #425014x92b. I adjusted the clutch as instructed in the owner manual and now it releases at the very top of the pedal travel. Is this a sign of being too tight or too loose?
Appreciate any assistance and have a fantastic day.
Wilburn "Red" Cox
Stephenville Texas
You're quite welcome Mr. Wilburn Cox!
Thanks again mechanic mark; I replaced the motion drive belt with a new one and adjusted everything out. Just finished and took the mower (minus the deck) out on my road for trial. All works as it should and the clutch releases just as you said, about 2 inches from the floor. I really appreciate your help. Have a great day. It is 99 degrees here in Stephenville Texas.
