Mower deck Toro timecutter swap 42 deck and make it a 50
beezer
Has anyone done this? I have a Toro ZTR 42 with Kohler 22hp and wonder if I can source a 50" deck. HP should not be an issue. Frames look the same.
Not sure it would work. In the SS/MX series, the 5000's frame seems a bit wider than the 4200, so I guess the spacing for the deck hooks is different.
