carguy1949
Just started to surge when not under load. Engage the blade and all is good. I've pulled the carb and cleaned it, replaced the fuel solenoid and heat shield with no change. Seems like a governor problem.
It could be a governor problem..
My cub cadet has the courage 19 in it and was doing the same, replaced the fuel filter and it fixed it.
