MowerMike
Over the years I've owned many cordless electric straight shaft string trimmers, but none of them have had all the features that I wanted, namely:
1) An adjustable length shaft to accommodate my short 5"-2" frame
2) A bump feed string head with a rapid reload mechanism that doesn't require disassembly to load new line
I've owned many string trimmers with the first feature, and many with the second, but none with both....until now.
It seems that the new Craftsman string trimmers offer both these features in their 60 volt line, but also in the top model of their 20 volt line. I drove over to my local Lowe's last Friday to check them out. The 60 volt model offers a 15" cut, a 2.5ah battery and a 4 year warranty. The 20 volt model offers a 13" cut, a 4ah battery and a 3 year warranty. The 20 volt model is more adjustable than the 60 volt model, and is lighter and cheaper, so I bought one. Quality appears to be on a par with Dewalt, with a brushless motor, battery cells made in Malaysia and all metal construction for the shaft. The string head is exactly the same part that is installed on the 60 volt model, and will accept 20 foot sections of either .080" or .095" twisted line, although Craftsman only recommends using .080" line in the 20 volt model, presumably to avoid overloading the smaller motor. It offers two speed range settings with a variable speed trigger.
One curiosity is that the string head rotates in a counter-clockwise direction looking down at it. This is opposite from all my other string trimmers, and the first time I used it with the head to the left side of my body I was pelted with clippings and debris. Once I reversed the position with my right hand on the auxiliary handle and my left hand on the trigger this problem ceased.
I have attached photos showing this new Craftsman 20 volt string trimmer alongside my EGO 60 volt straight shaft trimmer to show the difference in shaft length. The shaft is set at about its middle position, and at its its shortest position could probably be used comfortably by a four foot tall child.
