B brugg31 Forum Newbie Joined Mar 25, 2019 Messages 3 May 18, 2019 #1 When I mulch with my Honda mower it spits out a trail of grass right in front of the left rear wheel. Can anyone tell me why this is happening? And what to do about it. The underside of the deck is clean. Thank you in advance.
M mechanic mark Lawn Pro Community Leader Joined Jul 15, 2013 Messages 7,500 May 19, 2019 #2 htt ps://www.hondapartsnation.com/oemparts/a/hpe/50f7361ff8700233e4c92f1d/rotary-blade-1 are you using 1 or 2 blades? item 3 or 11? or both? #3 looks like mulching blade? have you sharpened blades recently? Last edited: May 20, 2019
B brugg31 Forum Newbie Joined Mar 25, 2019 Messages 3 May 19, 2019 #3 mechanic mark said: htt ps://www.hondapartsnation.com/oemparts/a/hpe/50f7361ff8700233e4c92f1d/rotary-blade-1 are you using 1 or 2 blades? item 3 or 11? or both? #3 looks like mulching blade? Click to expand... I have the 2 blade set up.
G Gatafly Forum Newbie Joined Jul 5, 2018 Messages 8 May 24, 2019 #4 It does that when you cut too much grass. Solution is to mow more often so it doesn't get so tall in between mowx.
