Simplicity Regent SLT 100
CDAN
My Simplicity Regent SLT 100 (2016) do not work well on backwards : much too slow ?
Thank you for your advice/CDAN
Hi and welcome to the forum!
I'm going to move this thread over to our Simplicity section to see if we can find you an answer.
check tire air pressures first, post your 7 digit model number, remove deck inspect drive belt & idler pulleys for replacement, use OEM Simplicity replacement parts
