Walk behind Toro Recycler 22" noise Help !!
alexio
Hello,
I have a toro recycler 22" and lately when trying do lawn, I hear a metal sound (rattling noise) then machine stop after few seconds.
here is a video of what is happening. https://vimeo.com/333772178
any advice could help me
and what is that rattling noise?
I have the same mower, and it, too, makes some nasty noises if I'm trying to mow tall damp grass with the side discharge closed. I would suggest that you remove the bag, and use a side discharge chute, instead....until you get that hayfield mowed to a more reasonable height. The Noise you are hearing is probably the belt tension pulley slapping around as the blade begins to bog down from the excessive collection of grass....which eventually builds up such that even the engine cannot handle the load.
