My Troy-Bilt mower with a Honda engine (GJAEA-7235523) is having an issue where the pull cord jerks back violently when trying to start. I've read in most cases that this could be due to a sheared/broken flywheel key. So, I proceeded to check the flywheel key (part #13331-357-000). After inspecting it, the key doesn't appear to be in bad shape, so not sure if this is the issue? There is a red mark and a slight scuff, but that's all of the blemishes that I can see. Please see the photos of the key below. Are these contributing to the violent jerk back? Any other ideas? Thanks in advance.
