Help with '65 Victor 21" engine id
noelbp66
Hi, I am starting to rebuild my mower but I'm not finding any numbers on the engine. I've wiped off most of the grime, but no luck? This is my first rebuilt, don't want to go too far until I find the correct info.
Thanks...
Do you have the original shroud that covers the flywheel? The engine numbers will be stamped into it.
Yup...right there on the flywheel housing. So much for my attention to detail!
Thanks guys...
That is the information you need, it is a 2 hp. Are you doing a tune up or complete teardown?
