Ida-Boy
I have used my Grasshopper 725 for years now pushing snow and it has done a great job. The last few years it has become louder and louder, making noise as if it chattering. New cutting edge, skid shoes and no difference. I even put a bolt to replace the pin since it has worn the adjustment hole (pin that allows you to adjust the angel of the blade) with no difference. There is slight movement as it attaches to the frame of the mower but the dealer says that is normal.
The only thing I see left is the linkage, with the foot bar that lifts the blade. That is all loose and think that may be the issue.
Anyone out there had this issue?
