Thanks for the encouragement...no experience with Vanguards so this is a new and more complicated than it needs to be beastie for me. 117 is what I found plugged on #2 carb cleaning...now open/clean. I've also gone through the fuel filter/valve and it is working...free flow of clean gas gets to the carb and drains from the bowl. I'll check the venturi and redouble efforts to clean every orifice I can find and blow it out again with compressed air.
Is there a telltale sign I can check to make sure the governor is set correctly? It lives under the fuel tank. You have to pull the blower/impeller from the crankshaft, unbolt the engine from it's stand and blower housing and move it sideways to get the fuel tank off (1 awkward bolt, no access) so you can see the governor linkage/setup. I've done that once already, but didn't notice anything bent or unhooked in the linkage. Just assumed it was probably correct given the difficulty of getting to it.
The big unknown with this engine/equipment is the husband of the PO...dumb enough to let a tank of gas evaporate into goo/gel, but smart enough to know what a wrench is and possibly use it before fiddling around. Lazy factor unknown...
