HR215-SMA GXV140 Engine swap
Dannyb
Trying to figure out what engine type will work on my Master series Honda walk behind. I found some reference that identified my mower engine as GXV140 Type MA4. I found a NOS GXV140 Type MA8. Does anyone know if I can use the MA8 on my HR215-SMA?
Current mower/egine information
Engine GXV140 8JAB-623499
Mower HR215-sma
Thanks so much!
Mower HR215-sma
Thanks so much!
I think the MA8 have no shaft stick out to drive the trans .If you can find GXV160 with PTO shaft then go for it,it is the engine for HR216 but will fit perfect for your HR215 deck and more power
Finally figured everything out. The MA8 is for the hydrostatic Drive and the PTO speed was too fast. I ended up swapping out the camshaft and the PTO gear and it fix the problem.
