BlazNT
- Apr 26, 2012
- 6,973
Sorry wrong bearings. I am losing my mind.
Of ALL the things in life I have lost,.....................I miss my MIND the most!
I almost always go to the hardware store and change bushings to brass.
Heard you lost your arse a few times too! ..:laughing:..:laughing:
I don't know if it is possible, but would having bronze bushings all the way
thru the hub rather than at the ends provide a better system?
I would think, a properly fitted FULL-LENGTH bushing would be a better choice, any room to drill and tap the wheel hub for a zerk..??
It would have to be drilled at an angle...
McMaster has the bushing stock in 3", 6 1/2" and 13" lengths....
I have to check the bore size thru the hub.
