Please help me get this leaf blower started
get a drinking straw and put some gas in it from a gas can and put your finger over the end that is in your hand to hold the gas in. then put the gas in the
intake hole inside the carburetor where the air filter is then choke it and try to start it. if it runs it is a fuel issue.
Ok. Did the straw this and it started. Did not let it run very long because gas spilled on my and garage floor. I mean the can. Should I do anything more than wipe up gas on floor? Dont want a fire.
Anyway it started.
FYI. My father just told me he replace all lines and bought 2 cans of Husqvarna gas. That is what is in there now.
Whay would be my next step. Thank you for all your helps guys.
Keith
Anyway it started.
Keith
clean up the gas and try starting it back up with out putting fuel in the carburetor with a straw.
Keep muffler off? You mean basically just put the line back on the intake? How to clean up the gas just soap and water? Thanks
yes keep the muffler off and put the unit back together like the air filter and cove as well as any lines you took off.
then put a old rag or junk shirt on the gas to soak it up off the floor.
Ok did everything you said. It started and started for about a minute. I gave it throttle and was ok. right around I would say running for 40 secs it sounded like it wanted to stall but did not. 20 secs later it stalled. I tried to start it again and same thing as the beginning it starts to kick but will not start
