Could someone please tell me the proper piston ring clearance on the Briggs Vanguard mod # 354447 engine
Also the torque value for the con rod , cyl head ,and the sump cover ?
thanks Dave T
thanks Dave T
Connecting rod 115 in/lb
cylinder head 165 in/lb
sump 150 in/lb
Ring gap reject is .030 inch. So that would be the max, but they don't list a minimum. If cylinder is correct size then rings should be correct gap is the way they look at. it..
if they are chrome moly then the bore has to look almost like a mirror when the honing is done.
Would a 320 grit ball hone be the best choice, Or a 240 grit to give me the proper cylinder finish?
please advise thanks Dave T
First of all do you have Cast iron sleeves ???? A magnet will tell you.....................
The cylinder sleeve is some kind of steel.
thanks Dave T
