jameswm1663
Hi there,
Recently I was given a Toro Power Throw snowblower with a 7 hp Tecumseh. Been sitting in a barn a while. I changed the oil, the fuel, and the spark plug. It is a pull start. Took the carb off and it looks clean. It will only fire with starter fluid in the air intake, turns over until that burns off. So I'm thinking it is a fuel flow issue. Does that make sense? Any offhand thoughts?
