so the Kubota will not be able to pull the mower..??
Not a 5 footer, unless you go very slowly and the stuff you are cutting is not heavy. Also, a 5-footer may be too heavy for the rear hitch to easily lift. Our Kubota dealer had a 42" land pride brush hog that would be perfectly matched to that small tractor, but I think it would pull a 4 foot OK if you don't try to go too fast in heavy stuff.
