About two weeks ago, suddenly my mower (Toro model 20334 -- 3100...) became much louder. Is there a muffler replacement that can be done? It is also running faster as soon as this happened so perhaps something else. Right now -- even with earmuffs, hard to stand the noise.
Yes -- was thinking might be a governor issue as the increased speed happened suddenly as if something came loose -- how can this be checked? I found what is called the governor spring, which seems fine -- not sure what else is needed. Also -- model number of the engine is 128T05-3123-B1 -- unit is about 8 yrs old. Toro mower is automatic choke electric start. When you start now runs a bit rough for about a minute -- then the speed increases to max and is loud.
Take the cosmetic cover off and the air filter box..... Then you will have access to the throttle on the carb........
Start the engine and if it runs away with you then put your fingers on throttle control at the carb....... See if you can control the speed like that....... You should be able to do that, you have a mechanical gov on that engine compared to a air gov on the small classics........
Like I said earlier it's a easy fix and cheap to .........
Let us know Mon Ami ..........
