wrenchmaster024
- Aug 28, 2017
- 8
i have a engine that when you pull start it it runs fine with no issues up until you stop it and try and pull start it again, there is nothing there on the cord. If you shake t on the ground it will work again, i tried removing the cover on the flywheel where the ball bearing balls are and there didnt seem to be any issue, i sprayed them with lubricant and tried again and same issue.
https://drive.google.com/file/d/1kGBlws7SBTYZ8q2lB2qDVrP3a3leLPjI/view?usp=sharing
https://drive.google.com/file/d/1zUXIsMX4nj57tqMnbzxMkVyR55L3fQd7/view?usp=sharing
