SidecarFlip
Only 2 things cause a belt to come off. Bad alignment (tracking) and not enough tension, other tahn total failure but usually that is caused by the preceeding conditions.
OK, I think I found why mine keeps coming off.
Got rear end up and found that rear left hydro mount bolt is missing completely and rear right is loose and lower third of threads on, holding it head down, as it is in the mount, rubbed off. I'll stop by Home Depot get some automotive grade bolts and nuts. Also, week before, I had front right hydro bolt broken, replaced, and left front loose, tightened and locking washers added to both of them.
After two Hustlers, I have to grant them one thing - they use piece of crap bolts for sure. Soft and undoing themselves constantly.
That in mind, rea of the left hydro is surely tilted down, causing fans to hit the belt. And come off.
