Briggs ID
Can someone tell me the hp of a 2013 Briggs 724cc engine?
thanks, gregjo1948
There will not be one fixed answer to this. Various stickers will be stuck on them. 22 hp to 26 hp. Best to post model number which should be stamped into one of the valve covers.
Walt Conner
24 hp. A simple way to convert cc to hp is. #cc devided by 15 devided by 2, will always get you close.
Walt Conner
I found the numbers on the valve cover. model--40777
type----3137G5
code--1301129YG
Back to my original post then.
Walt Conner
Are you saying the hp of this engine can't be determined. If so, I can't believe
the competition and also the government would likely be after Briggs for not legally identifying
the hp of their engines.
No engine manufacturer gives an exact hp for their engines. This came about because of a lawsuit against them, because the posted hp was not exactly what was advertised, most of the time slightly lower. Now all manufacturers use cc or ft lbs of torque.
