StatesboroMike
- Aug 2, 2018
- 26
I recently replaced the governor in my mower. It starts fine but runs only at low idle and will not respond to the tjrottle control. I checked the linkages and all seem correct. Any suggestions?
How able telling us the brand of engine and all numbers on the engine. We are not mind readers or standing next to you to see for ourselves. You have to help us, if you want us to help you.
I would go back and check your method of adjusting the governor, this manual might help you out. After you are sure that the governor is set properly, the next thing to check is your throttle control, is it opening and closing the throttle plate. If that is correct, start the engine and move the governor linkage to see it the speed increases and you have return pressure on the linkage.
https://drive.google.com/file/d/0B6NaqjIxWV1ySkZjTTA5TGltZEE/view
