John R
- Mar 9, 2016
- 240
I was cleaning around my engine and was wondering about under the shroud, I have removed the small covers on the shroud and blown out the engine fins they seemed very clean,
Should I go the trouble to remove the whole shroud, or is blowing out the top through the ports good enough?
I know grass build up under there can cause over heating, and head gasket failure, so I like to keep it clean under there
