JayTee
- Aug 12, 2014
- Threads
- 8
- 37
My Hustler Sport 48" Model #930222 has been a dependable mower, which my son is now mowing with. Thought I was 'moving up' going to a Raptor LTD 52"; the Sport seems heavier duty and I think my son got the better deal! :laughing:
The problem we're having is the the starter failed. Had it tested and it was roached. But, let me back up to a little history. The Sport had the original 4-5 year old battery when my son started mowing with it and he ended up having to replace it. Par for the course. In retrospect, he apparently did not fully tighten the ground lead to the battery, which apparently cascaded some failures. I believe that to be the source of the dead starter.
The guy who tested the starter told me that the loose ground would have been a likely culprit to damage the starter and about the arcing you can get in the starter solenoid due to a weak connection. Got a replacement starter and a replacement starter solenoid, just to cover bases.
The issue I'm having now is there is a 'Click' as soon as you switch into the Accessory/Run position, that I don't remember having before and it still won't turn over. Battery is charged. I've checked the fuse just before the starter solenoid and it's good.
Any thoughts about where to go next? Did the ignition also get damaged? I do fine with the physical stuff (starter/solenoid change) but not as good with troubleshooting electrical.
Thanks!
John
Thanks!
John
