svlawnmower
Hello:
Previous owner couldn't get this to run after it was given to them by their in-laws. I noticed it had stale fuel. I cleaned the carburetor and replaced gaskets, cleaned the fuel tank, replaced the plug, cleaned the flywheel and reset the ignition coil and it started right up. Itwould run but the sprayer wasn't any good. Put it in storage... this was late last summer.
This year, the problem:
I set it to "idle" and put it on choke and it fires and stops after 1-2 pulls. So I set the choke to 1/2 way between "choke" and "run" and starts and sputters. I move it to run and move throttle to fast, it speeds up like it is going to keep running, then after a few seconds stops. This cycle keeps repeating.
Speculating, it is as if it just burns up the fuel from performing the steps above and cannot draw more fuel and dies. I can smell fuel but I don't see fuel leaking anywhere around the carburetor but just a little around the gas cap (maybe not sealing tight anymore).
Spark plug is dry when checking.
I don't see white or black smoke
I set the throttle screw to 1 1/2 turns and the fuel mixture needle 1 1/2 turns.
Completely disassembled and cleaned the carburetor and fuel tank ... again.
Not sure what else to try.
Briggs and Stratton I/C Gold
Model: 133212
Type: 0159 01
Code: 95080207
Sears Power washer:
Model: 580 751500
S/N: 1659501
PSI: 1800
GPM: 2.5
Model: 133212
Type: 0159 01
Code: 95080207
Sears Power washer:
Model: 580 751500
S/N: 1659501
PSI: 1800
GPM: 2.5
