Flywheel ring gear needed
Weimsnks
303447 0411 01 Briggs v twin.
I am trying to find the replacement gear for the 808770 flywheel. I see many for sale but I cannot find the set that matches my engine.
Jacks cannot help me as they cannot find a part number
Any help would be appreciated
If I do the conversion kit, does the starter gear remain the same tooth configuration ?
The whole reason for this repair is the teeth are gone on both flywheel and starter.
I see the one link to Jacks doesn't work ..lets try this, AND NO it does NOT include a starter, I would assume it would use your present starter, which if you have an issue with,.. YOU either rebuild it, or replace it, with a rebuilt, or new one !!
Thank you, for the info. I just dont understand why other flywheels have a replaceable ring gear yet this one they decided not to. It is almost like they are forcing you to buy a new motor with just one part a third of a new engine.
Again, thanks for everyones help,
