2007 RZT 50 air gap on clutch
cuerno
The PTO stops working at times and it turns back on, it has a electric clutch, can't find my manual, anyone know the gap setting? I hope its not a safety switch.
Check out Youtube. There might be a video on there on adjusting it. I believe that the ones on my Scag recommend .15.
I saw about ten videos on YOU TUBE already, some say .012, ,015, .019, all of these were different engines. I called Cub Cadet but their recording will say hold on for tech support then after 4 minutes later a recording comes back to say, call the manufacturer of the engine. So i quess somewhere in the middle around .014 should do it, will give it a try tomorrow.
