JonnyBlaze
MODEL L100A. Working on a JD L100. Just replaced the camshaft now dealing with a brake/transaxle issue. The brake doesn't work and the tractor rolls freely when turned off and in gear and doesn't move when turned on and in gear. There is tension on the belt when parking brake is off. I see the pulley on the trans turning when its running. I removed the caliper to see if the two pins were stuck and they are not.
Is the brake rotor supposed to turn when moving the tractor back and forth? It doesn't move so I can see why the brake wouldn't work in that regard. What do I need to do?
More to the story: This is the second trans I put in it because I though the first one was junk as it was doing the exact same thing. But now I'm not so sure...
