LarryJohnson
Turns out, I had the right size tap. It didn't take anytime at all to do it on the bench. Threads are thin, but appear sufficient. I plan to add split lock washers just because the built-in washer doesn't have ridges for grip. Might be overkill cause everything will probably rust on anyway. Anyway, time for a beer and baseball.
