Need help finding spindle part # on Hustler 4600 72" HD Deck
teddypruitt
I have a Hustler 4600 that I've purchased that needs some fixing up. Just had the bearings go out on the left spindle. The deck is model# 924563 but does not have the standard pulley and spindle assembly that is shown in the parts manual. I don't know if what I have is an aftermarket or hustler brand accessory but looks like a deck reinforcement part with spindle built in. There is no bolt hole going through the pulley but the spindle shaft is built in to the pulley... anyways, I'll see if I can attach some pictures. Thanks for any info anyone can provide.
Teddy PruittIMG_20180421_104823.jpgIMG_20180421_104744.jpgIMG_20180421_104944.jpgIMG_20180421_104734.jpgIMG_20180421_104854.jpg
I think this may be the pulley setup that is used with the hydraulic pumps for the range wings which I don't have... I may find my own answer if I keep researching this...lol
If no answer pops up here for your specific question, might I suggest maybe call several Hustler Authorized Sales & Service places and ask to speak with the shop tech's?
I've done just that and have received a good source of help when asking specific's.
Even call Hustler Corp. directly (I've also done that too) and ask to speak with one of their Engineers (for your specific model mower) and inquire specifically for what you need? They are big help because who else (other than shop technicians who specifically work on all Hustler mowers) know Hustler mowers better?
But hopefully someone here will chime in with some good info.
Good Luck!
