Hi Guys! I put the engine back into my 1622 after rebuilding.When I started it up I noticed a howling noise at low engine speed. It seems to be coming from the disc couplers that connect engine to the transmission. Noise seems to go away at wide open throttle. (or else the engine noise is drowning it out) Is there a way to ensure alignment of the disc couplers? Thanks!
