T Tractorkid1250 Member Feb 26, 2018 #1 Anyone know where I can get an LED replacement to MTD "925-0963" headlights? My tractor headlights are burned out and they are weak and dim.
C cruzenmike Well-Known Member Feb 26, 2018 #2 https://support.mtdproducts.com/s/article/10581-1 Maybe this will help?
Boobala Lawn Pro Mar 20, 2018 #4 Tractorkid1250 said: Yeah, I think these will work. Click to expand...
mhavanti Well-Known Member Mar 20, 2018 #5 My old MTD YardMan has 1056 back up light bulbs as the headlight bulb. Run down to the local box store and pick up a replacement for whatever bulb you have in your MTD in a LED replacement and you'll be all set. Good luck. Max
