Engine has major issues
My tractor has some major issues. It is a 1994 MTD powr kraft. It has an 18hp briggs and stratton opposed twin, and it doesn't run. Has spark, fuel, and compression, but it won't run. It doesn't run after it developed a fuel leak into the cylinders after running it one time, and it leaked some of the tank into the oil (when i checked the dipstick, the oil was halfway up it), installed a fuel shutoff to stop the leak. I pulled the top and side engine covers off, cleaned out a mouse nest, and put it back together. It sat for about 6 months total; I pulled the plugs to check for fuel in the cylinders, found none, and then changed the oil. I accidentally put a bit too much in (thanks Briggs for saying it took more than it actually did) and then took some out, and when I went to start the tractor, it didn't want to start. Thinking it was the carb, I pulled the carb off, then after a month or so put it back on, and the tractor somehow started, but it didn't shut off. It didn't run away, but stayed at idle, it was smoking like crazy, and even pulling the spark plug wires didn't stop it. It only died after closing the shutoff. Haven't touched it since. I did notice that the reverse safety switch wires were pretty much nonexistent, and only a small ~3 inch wire remains. I think I either put a ground wire in the wrong place, or forgot to connect it all together, the key switch might be bad, or it might be the charging system (The tractor has some jerry rigged wiring). Note: Has a good 1 year old battery and good fuel. Any suggestions? Thanks in advance.
Can't understand engine running with plug wires pulled ! were BOTH pulled ?? VERY STRANGE, anyway I found a wiring diagram that MIGHT be SIMILAR to your model,
https://www.partstree.com/parts/mtd...-kraft-lawn-tractor-1994/electrical-switches/ you will have to use your enlarge & zoom functions to see this better also navigation bar @ top of diagram
You failed to post your machines information, needed to find the CORRECT manuals ( if available,)(see EXAMPLE)
.....GET INFO.JPG It's best if you get the wiring straightened out before going any further, post your machines info. and we might get this issue solved.....
Yeah, both were pulled, and it was still running. For now I guess I'll run it a bit, and just cut off the fuel to stop it, but like the issue with it not starting, it'll probably have magically sorted itself out.
My guess as to why it didn't want to run at first is either the float is junk, or the fuel is bad or something; but I can't be sure, as there WAS fuel in the intake, and it has spark, but it wouldn't run. I did notice at the first attempt at starting it that it was turning over a bit slow, but after I took out some of the oil about a week or so later, it sorted itself out after cranking for a few seconds, then instantly started. It ran nice, despite its issues, and it doesn't surge at idle like most tractors. I have not run it over probably about 10% or 15% throttle. I put in the correct oil (as Briggs recommends, from 0 to 100, 10W-30).
Overy heated engine or super high compression are the 2 things to cause that. Neither is good. I would start with removing the shroud and checking for a little animal nest.
My tractor's engine runs good, it doesn't backfire, the timing is good, it generates enough power, doesn't knock or anything, doesn't leak oil (but i did notice drops of something on the floor near the front of the tractor when pushing it around, possibly fuel?), it hopefully doesn't burn oil, and it only smokes because the fuel soaked through the rings before I put the fuel shutoff on. Other than the fact that's it's super inconsistent, it's a solid tractor for something we got for free.
Tractor Info:
MTD Powr kraft (1996, not a 1994) 46" cut, 18hp Briggs opposed twin, hydrostatic drive
I don't have any other info at the moment. Well, I do, but my computer won't load the pictures.
Tractor Info:
See here for locating your ENGINE information ... YOU did SAY OPPOSED TWIN ..!
https://www.jackssmallengines.com/jacks-parts-lookup/briggs-stratton-model-locator.aspx
one of these should be your Engine O/H Manual ....
https://docs.google.com/file/d/0B6NaqjIxWV1yZHlwUk9CWlNwYVE/edit
https://docs.google.com/file/d/0B6NaqjIxWV1ybHphbUNTQUNNR2s/edit
Hopefully Figured it out
Ok, so me and my brother (hopefully) figured out the issue. It turns out that there's a wire that goes to the coil, a black wire which is a kill switch. So, it basically grounds the coil and shuts off the engine. As it would seem, it was not even attached, which most likely explains the engine not shutting off. Also, I was wrong. It shut off with the plug wires pulled, the fuel shutoff didn't do anything. Well, I think that the wire was accidentally pulled off after me and my brother pulled the top engine cover off.
MTD Powr kraft Limited edition (1995)
Model number: TMO-3400005 134Q699H088
Serial number: 2C044H30177
18HP briggs and stratton opposed twin
Manufactured: February 1, 1995
Model:422707
Type:1214 01
Code:9502015A
Powr kraft 2 2,10,18.jpgpowr kraft 2,10.jpgTractor coil 2.jpgTractor coil 1.jpgCoil Kill wire.png
Here are some pictures of the tractor in its current state.
(My brother's profile on this site is TractorCrazy, he has a Cub 1250, A Cub 129, A mowett mustang, a cub 147, a cub cadet 72, and a piece of junk powr kraft)
It takes time for an engine to die by shutting off the fuel. The engine runs on the fuel in the float bowl until it's gone.
Update
We got the tractor running, and it runs good. It genuinely surprised me. The thing starts good, and after it gets fuel into the carb, it starts on the first crank. The idle isn't too bad, it doesn't surge, but it seems like the carb might need to be cleaned. Eventually I might empty the fuel system to get the gasket that was on the bottom of the fuel cap (but is now in the tank) out, and to clean it. But yeah, the tractor's fine. I put it together on Tuesday and ran it for a while. I am concerned about the possibility of it leaking fuel into the oil again through the float bowl, but oh well. But yeah, nothing leaks, good transmission, engine runs good, etc. Need to put some fuel in it eventually (there's only about a teaspoon of fuel left), and I need to put the body panels back on the tractor.
