robert@honda
Honda is in the process of updating our popular HRR and HRS models with the latest versions. Most of the changes are just cosmetic, while some get a little nicer hardware.
Let's get started!
The value-priced HRS models (version K6) get the following updates:
• VKA “Smart Drive” model introduced and replaces SKA model.
• VKA model uses variable speed transmission and replaces single-speed transmission.
• Cutting height changed to 1 in.~3.5 in. 1 1/8 in.~4 in. (same as HRR)
• Quick release 2-position handle applied.
• Textured mower deck paint.
• Color changed to Emboss Bright Gray Metallic (NH-B67M)
• Tire tread changed to improve traction.
• Wheel hub color changed to Vintage Gray (NH-462R)
• Texture (grain) finish applied to wheel hubs.
• One piece (HRR style) rear handle stay and height adjuster panels.
• New front mower deck decal.
HRS216PKA (push model, side-discharge, mulching single-blade):
HRS216VKA (push model, side-discharge, mulching single-blade):
HRR Series:
New HRR models are at version K10, and get the following:
• Color changed from Rose Champagne to Emboss Bright Gray Metallic (NH-B67M)
• One piece rear handle stay and height adjuster panels.
HRR216PKA (push, bag, twin-blade mulch, Clip Director):
HRR216VKA (SmartDrive, bag, twin-blade mulch, Clip Director, Roto-Stop Blade Clutch):
HRR216VYA (SmartDrive, bag, twin-blade mulch, Clip Director):
HRR216VLA (SmartDrive, bag, twin-blade mulch, Clip Director, Electric Start):
Note: The HRX and Commercial HRC models are unchanged for 2018.
Let's get started!
HRR Series:
