Boobala
Your part number should be STD365402. I am not finding it crossing to the part number you gave me. Check to see if the pins have the same letters on them.if not you need a different ignition switch.
I went and located the Ign. switch diagrams , the craftsman was already on the page you sent in link, but I found HIS oregon switch online, I would say for sure the switch is the problem .. see pics...
https://www.manualslib.com/manual/32415/Craftsman-917-25693.html?page=28#manual see bottom of page view of switch
YOU provided him a good number (std 365402)
