Blades Typical mower blades VS Mulching blades
Typical mulching blades are not designed to move grass up a shoot. They are designed to keep the grass under the deck to get recut over and over.
I will give it a try ;) But sounds great, less grass in the bags :)
If things don't seem to work out, I will switch back
TY
Iv`e used Gator blades for years on a 1863 54" deck with no problems using a mow& vac.
That's a powered vacuum system though, right? I got the impression that the OP is using a bagging system without a vac unit which relies on air created by the blades to send the clippings into the hopper. I could be wrong though.
