Snapperfreak
I bought my srm2100 new almost 20 years ago. It's the only item out of all my equipment that was purchased new. It's always been well maintained and just used at home. But a frequent problem, even when it was relatively new, was that the cylinder would tend to flood with fuel making it impossible to start. It's always leaked fuel (or maybe oil, seems thick) out the muffler and other places around the engine making it really gunned up after a few uses. A couple years ago I replaced the carb with a new sams carb, new fuel lines and filter and air filter all at once to see if that helped. Since the new carb was installed its only seen full synthetic fuel. Now it won't start even if I pull the plug, dry it off and put it back in. Floods immediately. Any help would be appreciated. Thanks.
