Need help identifying part...wiring harness (2004, 225/61)
Reubenjet
I need help identifying this part assembly...In the picture it ends with the white, male end. It is part of the wiring harness and has wires going to both sides of the mower under the frame. The female end is coming out of my Kohler engine. Does anyone know what the part number or assembly name is? Thanks!HARNESS.JPG
It looks like there are four wires coming out of the male side? Can you pull the wrapping back to tell what color they are? Sometimes there are different colors going into a harness thjan there are coming out the other side.
I need help identifying this part assembly...In the picture it ends with the white, male end. It is part of the wiring harness and has wires going to both sides of the mower under the frame. The female end is coming out of my Kohler engine. Does anyone know what the part number or assembly name is? Thanks!View attachment 33817
NOT sure, but I doubt you will find them in the engine OR mowers parts lists, BUT try this link as a starting point that may help you to replace those connectors . Keep us up-dated . :thumbsup:
https://www.google.com/search?q=molex+connectors&ie=utf-8&oe=utf-8
That part will be a dealer only part. The name it is given in any parts diagram is "Wiring harness". You need to call a Grass Hopper dealer and see if they even cary that as an indivual part.
Thanks! The parts are...184936-connector
184950-terminal
Curious... did the dealer have the part #s ..??? That info should be helpful to others .
No, the dealer had to contact Grasshopper for the part #s. I have no idea why it is not listed in the parts diagram included with the owner's manual.
Good thing it wasn't a "molded-rubber" connecter , THATS a REAL P.I.T.A. , soldered many wire harness connectors in the marine and aircraft trades I was in , glad that's behind me !
