heavy_kevie
Out mowing Sunday, got the job halfway complete when the PTO clutch disengaged on its own. Pulled into the garage, put the mower up on jack stands and took a look at the clutch wires. Wires looked good, connector looks solid. Checked PTO fuse, fuse looks good. Pull out the DVM, check for voltage at clutch connector, 0 volts with switch engaged. Battery voltage is 12.4 volts, put charger on, cleaned battery posts and wires. Check voltage at fuse, 0 volts on either side with and without clutch switch engaged. Disconnected OP switch under seat, 0v at fuse. Jumpered OP switch, 0v at PTO fuse. Getting lost now. Adjusted PTO clutch to 16 thousandths air gap, still no voltage at fuse :laughing:. The model number is 2690444, model year is 2007, s/n is 2012618170, 537.3 hours. Anybody have a service manual on this mower or at least a wiring diagram?
