Thanks for the advice. It is a 2-position switch. My Grasshopper rep just said to turn it on and try the wires on one side first then across until they work. I don't have a tester.First is it a 2 (on off)position switch or 3(on on off).
Turn it to the on position and with continuity tester find the two that have it. Plug your wires into them.
His way will work as well.
