classy_gene
- Jul 14, 2017
- 6
I have a 2500 Compact Hustler. It has about 1500 Hours on it. The last time I mowed it kept loosing speed, I parked it in the garaged and finished up mowing with my other mower. I went to use it today to see if I could figure out the problem. The drive belt for the pumps I replaced last year and is tight and clean, no oil or dirt on belt. The mower won't move. If I jack up the rear and have the drive wheels off the ground they will rotate slowly but I can stop them with my hands. If the engine is turned off I can freely rotate the wheels which I thought was odd because it never rolled before. Is there a bypass valve stuck open or what should I be looking for?? Thanks in advance.
