starting motor question
corvairbob
i have a 17 hp briggs & stratton intek v twin engine and the starting motor bendix broke. i did not see any numbers on the starting motor but on the bracket i see these numbers on the bendix side it is 9807015m and on the back of that bracket it is 28154. are these bracket number issued to particular motors so if i find a motor with that same number it is good to use it? i looked all over the mower and the engine and i just do not see any data tags or numbers. seems they must be some on there somewhere but i just don't see them. so i'm asking if the bracket number may help to id the motor? thanks the mower is a rider it says yardman mtd on the decals and the number i find are on the floor and they tell me the attachments this mower will take. and the only number i found was on the axle that one was 618-0307 s# q-004500 . but my guess is that axle was used on number of machines. thanks for any help you can provide. bp
The model type and code numbers should be stamped into the valve cover on the side opposite the fuel pump
Quote Originally Posted by Tinkerer200 View Post
"i have a 17 hp briggs & stratton intek v twin engine"
Walt Conner
"They do exist." darrinster
Please furnish the model number for that, that will be a new one on me.
Walt Conner
Walt Conner
Walt Conner
Still waiting
Walt Conner
corvairbob
IF you expect to get any help, you need to post the model number of your engine OR a picture of it at least. Your description does not identify the engine.
Walt Conner
The worm part of the starter clutch is part number 692024. The gear is 695708, or you can get the entire drive assembly with all the parts that are on top of the starter which is part number 696541
