So while cutting the grass today I noticed that if I put the transmission in any of the gears that it would not roll backwards. One wheel would lock which allows you to pivot. I assume this might be by design but wanted to check. In order to actually be able to go back and forth I have to put the transmission into Neutral.
Is this just how they are setup? Or should it roll backwards even if it is in gear?
