C cambre Well-Known Member Joined Aug 2, 2014 Messages 324 Jun 4, 2017 #1 I have a Stihl MS 362 chain saw & removed the plug to clean it & check the gap. The manual says .02 inches. This is paper thin or I am reading my feeler gauge wrong. The spark plug looked like is was previously set about .20 inches.
R Rivets Lawn Royalty Community Leader Joined Mar 11, 2012 Messages 16,297 Jun 4, 2017 #2 The manual is correct. .020 is twenty thousands and correct. .200 is two hundred thousands and incorrect.
C cambre Well-Known Member Joined Aug 2, 2014 Messages 324 Jun 4, 2017 #3 Rivets said: The manual is correct. .020 is twenty thousands and correct. .200 is two hundred thousands and incorrect. Click to expand... Thanks Rivets for the quick answer.
