mhavanti
- Oct 12, 2014
- 924
I can tell you what I'd do, I'd get the SD and if the deck you choose is too narrow to get you the 13-6.50-6 front tires and spindles and the extra wide rear tires. Tell the dealer to keep his two hundred and configure the mower with the extra wide tires front and rear and get to mowing.
You'll do better to use your time for you than wait trying to save nine bucks if any at all waiting for fall. A Raptor SD will give you back part of your time to spend on you.
