I have a Grasshopper 725D & the blades are made out of hard steel, witch I like. I don't like to use my bench grinder to sharpen the blades, I prefer using a file. I have a large lawn that I seeded twice with lawn fescue the last two years. I sharpen the blades before each mowing, I like a good clean even cut. I'm really not nuts. I like a good looking lawn. My problem is finding files that will do the job. There are a thousands on line & seems like hundreds of companys that make them. I would like advice on this from you guys & gals, thanks.
