cruzenmike
- Feb 10, 2017
- Threads
- 59
- 858
My step dad gave me an ExMark that he said was having a hard time holding a charge. He stated that after a couple of cuts (about 2 acres each), the mower would have a hard time starting. He did replace the battery with a 350 CCA unit this past year and it was put on a trickle charger after every use, so the starting issue, for the time being, is no more. When I got the mower I used it a few times, not paying attention to the sticker stating to engage the PTO at half throttle. Me being the stickler I am for running and maintaining equipment per the manufacturer's recommendations, the first time I engaged the PTO at half throttle, the mower died. While this may have been half throttle position, it may have not been the RPM between idle and max. So now comes to the actual question, if the voltage regulator is bad, could it be the cause of my problem? I have verified with my voltage meter that I am receiving 30Vac from the alternator, which means that I have a 16 amp system. The down side, is that I do not have a meter than can test DC current over 10 amps, nor do I have the special tool (DC shunt) that will allow me to test with my meter. I just experienced an issue with my Cub Cadet where the voltage regulator was going bad causing the battery light to come on, but I never had it stall. it just seems too coincidental that the battery is not staying charged and this issue is happening on the same machine. I appreciate any help.
FYI, the engine is an 18HP Briggs Vanguard 356777 0115 E1
Mower is a LCT18BV483
Mike
Mike
